Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-27-2006, 07:35 AM   #1
cmb13
CF Senior Member
cmb13's Avatar
Send a message via AIM to cmb13
Default What do you guys think of this idea?
I'm about to go with the 1/2" MDF for the base of my amp rack. One of my issues, though, is that in the C6 vert with the power top, there is a fabric cover that comes down separating the trunk from the top. It comes down vertically, then slants inward towards the passenger cabin. I wish I had a picture, but my digital camera is out.
The issue is that there isn't a lot of clearance. Therefore, the higher my setup is, the further back into the trunk it will stick out.
In the interest of maintaining trunk space, I was wondering what you think of this setup. How about getting the 1/2" MDF for support, but cutting out around the amps so I didn't lose that 1/2" of vertical height; this might allow me to push the amps back about 1-2" extra. The MDF would be used to support the amp, sliding around it, and it would also house the crossovers, power distribution boxes, and support the facade.
Eg:
_______....AMP....______....AMP...._____
___________________________________
Smart idea or ridiculous???
cmb13 is offline   Reply With Quote
Old 03-27-2006, 08:22 AM   #2
krl
CF Senior Member
krl's Avatar
Default amp rack
Eg:
What if you used a flat steel plate for bottom and save even the 1/2 inch then screwed up through the plate into MDF sides, that seems to me to be a thin bottom option and still have a ridgid base
krl is offline   Reply With Quote
Old 03-27-2006, 10:58 AM   #3
cmb13
CF Senior Member
cmb13's Avatar
Not a bad idea - with steel, I can get strength with a thinner base. You have a C6 vert, you must know what I'm referring to with regards to the panel in there.
Where would I get steel? Do they have it at, say, Home Depot? Also, can I screw the amps into it, or would I need a nut/bolt arrangement?
Old 03-27-2006, 11:46 AM   #4
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
you can get steel sheets from a home depot type of place. it is readily available. Looks like a cool idea so far. I agree on the steel instead of mdf if you are trying to save space. You should be able to just use sheet metal screws. The self tapping ones. you'll be good to go.
DPG is offline   Reply With Quote
Old 03-27-2006, 11:53 AM   #5
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
why dont you just forget about the 'amp rack' enclosure and instead just make a facade out of 1/2 mdf, cut the holes for the amps and x-overs and then secure them to the underside of the facade?
Code:
________            __________  facade
      ------------------           amp
       ^              ^               drill up from there
scott_fx is offline   Reply With Quote
Old 03-27-2006, 12:15 PM   #6
cmb13
CF Senior Member
cmb13's Avatar
Interesting idea - something to think about. Thanks!
Old 03-27-2006, 12:34 PM   #7
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
ok, whats a facade? I've been trying to figure it out and all I can see is that it is just a partial cover for a amp. Am I right, or way off?
Old 03-27-2006, 12:35 PM   #8
scott_fx
CF Senior Member
scott_fx's Avatar
the amps will pop up through the facade a bit. i did that on my first install (wayyyy back in high school) and it looked pretty good.
Old 03-27-2006, 01:21 PM   #9
cmb13
CF Senior Member
cmb13's Avatar
Quote:
Yup!
Websters -
Facade:
1. The face of a building, especially the principal face.
2. An artificial or deceptive front.
Reload this Page What do you guys think of this idea?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What do you guys think of this corvette?? stingraymaniac C3 Tech/Performance 45 03-08-2004 11:34 PM
[SMC] What do you guys think of this? your drinking buddy Southeast 47 03-07-2004 09:05 PM
new to C4 forum!! what do you guys think of 84's? radwebster C4 General Discussion 30 04-06-2003 03:52 PM
Heh...What Do You Guys Think Of This Tranny??? Viet Nam Vett C1 & C2 Corvettes 39 04-06-2003 12:00 AM
What do you guys think about this appearance mod? CentralCoaster C4 General Discussion 16 02-25-2003 04:28 AM
Tell me what you guys think about this idea......... Ryan77 C3 Tech/Performance 34 02-10-2003 07:50 PM
What do you guys think about this Z? Dr. Evil C4 ZR-1 Discussion 32 12-13-2002 07:59 PM
[Pic] What do you guys think of this for my new seats? _freakmonkeydogboy_ C4 General Discussion 13 12-09-2002 03:09 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
