Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2006, 11:24 AM   #1
Dylan 93Z
CF Senior Member
Dylan 93Z's Avatar
Send a message via AIM to Dylan 93Z
Default 2000 Bose questions..
I relaize I need the adapter to make my Bose speakers work with an aftermarket HU, but do I need any other adapters and/or wiring harnesses to hook up a radio?
Dylan 93Z is offline   Reply With Quote
Old 02-24-2006, 11:35 AM   #2
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
radio antenna adapter
DPG is offline   Reply With Quote
Old 02-24-2006, 01:18 PM   #3
Dylan 93Z
CF Senior Member
Dylan 93Z's Avatar
thanks, i assume i will still retain all of my factory speakers? and not have to buy additional ones?
Old 02-24-2006, 01:36 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
correct unless you want to improve the sq then you could purchase 3.5" speakers to replace the 'twiddlers' in the bose system
scott_fx is offline   Reply With Quote
Old 03-01-2006, 10:38 AM   #5
Dylan 93Z
CF Senior Member
Dylan 93Z's Avatar
for the research I have done so far I am guessing if I wanted to keep the door 'subs' I would then need to spend 100 bux for the soundgate but if i decide to just replace those speakers with aftermarket ones then there is no need to spend the cash on the soundgate and i could better spend the money on better speaker including the 3.5" twiddlers?
Old 03-01-2006, 04:12 PM   #6
fej
CF Senior Member
fej's Avatar
Basic $5 plug adaptor to fit the stock gm harness and give you all but one lead needed to splice in your aftermarket HU. You can tap the yellow lead located in the top left corner of the computer in the passenger footwell behind the cover for it.
IMO it is worth spending a couple hundred dollars on a set of component speakers in the front and pick up the package deal from vrumvrum for a headunit mounting plate and speaker plates built to your application. Pick up a 50 foot spool of speaker wire (whatever you want to get I personally do not spend "real" money on speaker wire) and a set of RCA's from Knuconceptz.com or your local speaker shop ( I do recommend that you spend some decent money here however). You will be amazed at the sound quality difference that replacing the blose crap will make.
If you wanted you could keep the rear speakers with an aftermarket deck but I personally do not know if you can use the factory speaker wiring or not to do that without an adaptor.
G'luck
Fej
fej is offline   Reply With Quote
Old 03-01-2006, 04:18 PM   #7
Dylan 93Z
CF Senior Member
Dylan 93Z's Avatar
cool thanks for the responses and the help!
Reload this Page 2000 Bose questions..
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 2000 Corvette Coupe Spin36o C5 Corvettes for Sale 14 09-30-2005 12:56 PM
2000 Black FRC 11k miles SANMAN C5 Corvettes for Sale 35 09-20-2005 05:50 PM
2000 Silver Vert SilverRoadster00 C5 Corvettes for Sale 47 07-08-2005 09:52 AM
F/S: 2000 TRIPLE Black Z-51, 6-speed, GMPP, etc. rickyb C5 Corvettes for Sale 23 11-26-2004 12:20 PM
FS: 2000 MY, 22k miles, 27k$. 427_Roadster C5 Corvettes for Sale 15 05-07-2003 03:02 PM
2000 Hardtop for sale Garceeya C5 Corvettes for Sale 21 01-19-2003 11:32 PM
FS - 2000 Pewter FRC / MN6 - 16k miles - Must Sell Sayow C5 Corvettes for Sale 9 09-10-2002 10:58 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
