Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2006, 06:41 AM   #1
jan-erik
CF Senior Member
Default Bose Radio jumps out of the station and then comes in again on an -85
I have a problem that make me go up the wall. The radio (stock Bose)is good when receiving, but suddenly it looses the station and this hizzing noise (white noise) comes being away from the station.Then after a while it comes back again. The intervals can vary very much from days to just half an hour. When I lose a station it comes back within minute(s).
I have a suspicion that it might be the phase locked loop, but this seems as it is a known problem.
Are there anybody here who has solved this problem or at least got the diagnosis and what was repaired. I will do it myself as radios has been my profession. To send it to USA (live in Norway) will cost more than a same sort of radio.
Any help will be greatly appreciated
jan-erik is offline   Reply With Quote
Old 02-24-2006, 11:50 PM   #2
rightofway
CF Senior Member
rightofway's Avatar
Send a message via AIM to rightofway
i had a similar problem but it would sometimes change to another actual station or nothing and i could do nothing to change it back then my display went out almost completely and i now have a giant hole in the dash where the stereo used to be
this seemed to happen most when the outside temp was under 70ish*F
heres a bump for ya as i too am interested in an answer
rightofway is offline   Reply With Quote
Old 02-26-2006, 12:37 AM   #3
parafrog
CF Senior Member
parafrog's Avatar
Location: Tucson, AZ. L98-85 AUTO COUPE: 120k MILES: daily driver. SOUND OFF IF YOU'VE BEEN THERE. Ex-Jumpin' Junky-82nd Airborne-2/505 PIR: 1st ID-1/16th Inf: Recon Marine Retread. GOD BLESS GRUNTS.
my 85 does the same thing. if i bash the pass side of the console it comes back (old fart who remembers when you bashed tube tv's). sometimes that will only work for a couple of minutes. i was thinking it maybe a loose antenna connection to the radio-caused by years of vibration. but i would really like to know.
as far as repair, i don't need to keep the car stock, and a poor receiver with only 4 presets is just begging to be replaced with a modern unit. one drawback is trying to fill the huge hole old gm radios leave in the dash.
frog.
parafrog is offline   Reply With Quote
Old 04-03-2006, 02:17 PM   #4
onedef92
CF Senior Member
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
onedef92's Avatar
If the Bose stereo unit powers up but you have no or distorted audio, no FM, some/all speakers work intermittently, or the system is dead, check, the CDM (Tuner Pre-amplifier Box.)
It can be found under the dash board on the passenger side ('90-93 in most cases) or in a rear pocket on the passenger side of the vehicle ('94 and up).
I have seen the units behind the seat submerged in water and have corrosion, also check connectors below the CDM box.
When the head unit is turned on and off you should hear a click from the relay inside the CDM box. If you have snapping and popping from some of the speakers you will have to trouble shoot to the defective amplifiers separately.
Is it a defective CDM box or Bose amplifier? You will need to swap working speakers enclosures with nonworking speakers enclosures to determine if it is the CDM box or Bose amplifiers that are defective
http://www.carstereohelp.com/corvette.htm
onedef92 is offline   Reply With Quote
Reload this Page Bose Radio jumps out of the station and then comes in again on an -85
Tags
bose, box, cdm
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
