Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2006, 08:54 PM   #1
Drav1212
CF Senior Member
Default C5 New Alpine HU Install Help
Just in the process of installing NEW HU in my C5. Got the Soungate spliced with the Alpine wiring harness.
My question is this:
RED WIRE ----
1) Where did you guys splice in the RED wire?
2) Is the RED wire needed, since we have the yellow wire?
THey say to splice the red wire inot the ingnition BROWN wire. At what point do you connect the red wire to the BROWN ignition wire?
Thanks,
D
Drav1212 is offline   Reply With Quote
Old 02-22-2006, 09:20 PM   #2
mode101
CF Senior Member
mode101's Avatar
I am about to start the exact same project, and have the same questions. I also purchased a gmcrv1 and was going to try to install it saturday.
I do not see why we couldnt use a T-TAP on the OEM harness in the car (for the orange illumination and red ignition wires) and connect the wires from the alpine harness directly to the t-tap with quick connects... anyone see a problem with that ?
The red wire is for the ignition.
Does the soundgate keep the radio playing after the key is removed as long as the doors arent opened?
T-TAP (left) Quick connects (right)
mode101 is offline   Reply With Quote
Old 02-22-2006, 09:22 PM   #3
mode101
CF Senior Member
mode101's Avatar
Also, the instructions that came with the gmcrv1 say to remove the convertible top storage cover for this install.. is that really needed???
Old 02-22-2006, 09:33 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
RED WIRE ----
Thanks,
D
i've never installed one but you would need both, one gives the unit power and the red wire turns the soundgate on and off with the ignition. you can find that wire in the pasenger footwell or tap off fuse no 22. check out the c5 faq for more info on what wire to tap off of.
you are going to lose rap features when you remove the stock h/u. there are some products available to retain rap, such as the unit from top down tech
scott_fx is offline   Reply With Quote
Old 02-22-2006, 09:52 PM   #5
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
Send a message via AIM to diviniti
There is a red wire that you can tap off of the ignition.. Look in the pic, the arrow shows where it is. Take the panel off (which it should be already for the radio install.) You will see 1 red wire. That be it.
On your H/U. Red is Ignition (Only on with Ignition) Yellow is constent/Battery (On all the time).
diviniti is offline   Reply With Quote
Old 02-22-2006, 10:02 PM   #6
fej
CF Senior Member
fej's Avatar
I used the factory plug in adaptor for my install .. tapped into the factory red wire and ran a seperate yellow wire located in the passenger footwell above the left corner of the brain there. There should be 3 wires there that are short and taped together. The yellow you can use for the radio install.
Fej
fej is offline   Reply With Quote
Old 02-22-2006, 10:04 PM   #7
mode101
CF Senior Member
mode101's Avatar
Quote:
Fej
Isn't this the same 3 wires that a lot of people tap into for V1 hardwire?
Old 02-22-2006, 11:39 PM   #8
Drav1212
CF Senior Member
I love ur radio, but too expensive for me
Old 02-23-2006, 12:04 AM   #9
Drav1212
CF Senior Member
Click here: Installation of Vette Essentials' Custom Emergency Brake Handle and Boot
Further instructions
Old 02-23-2006, 12:05 AM   #10
Drav1212
CF Senior Member
http://www.vetteessentials.com/instr...brake_h_b.html
Go here not sure if link will work if not copy and paste
Reload this Page C5 New Alpine HU Install Help
Tags
c5, hu, installation
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Audio FAQ bogus Audio/Electronics 49 01-31-2012 04:41 PM
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
C5 Audio install completed, tested and now revisited - help needed AllCammedUp Audio/Electronics 9 04-29-2003 04:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
