Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2006, 01:47 PM   #1
mechanix19
CF Senior Member
mechanix19's Avatar
Send a message via AIM to mechanix19 Send a message via Yahoo to mechanix19
Default I can't get the stereo to fit?????
I'm trying to install a Jensen VM9510in my 98. It seems like it is too long to fit where the stock stereo was. After I push it in it looks like there is still about a good inch and a half to go. Did anyone else run into this problem or am I just not doing this right? Thanks to all help in advance.
mechanix19 is offline   Reply With Quote
Old 01-18-2006, 02:07 PM   #2
Prism911
CF Senior Member
Did you try using a ruler?
Prism911 is offline   Reply With Quote
Old 01-18-2006, 02:10 PM   #3
mechanix19
CF Senior Member
mechanix19's Avatar
In other words mr sarcasm, if you had this problem what mods did you do to get it to fit?
Old 01-18-2006, 02:20 PM   #4
14U2ENV
CF Senior Member
St. Jude Donor '04-'05-'06
14U2ENV's Avatar
Location: Lino Lakes, MN _________________________ I Figured out how to do this!
Did you remove the two metal tabs on the top of the radio support?
Did you remove the black plastic clip holding the air shute together?
14U2ENV is offline   Reply With Quote
Old 01-18-2006, 06:55 PM   #5
bfhawki
CF Senior Member
St. Jude Donor '06
In recently installed an Alpine unit in my C5 and I had to bend the metal bracket that supports the back of the radio out of the way. I did this by hand and just bent it back. It is pretty soft metal and not to hard to bend. My deck also had RCA outputs out of the back of the deck and I had to use 90 degree RCA adaptors instead of running my rca cables straight into the radio.
bfhawki is offline   Reply With Quote
Old 01-20-2006, 01:41 AM   #6
markcz
CF Senior Member
markcz's Avatar
I just put a Kenwood HU into my '01 using one of the standard plastic mounting adapters, and I also had to bend the lower support bracket before it would fit all the way in, that seems to be how it works.
I'm not sure, but I think the mounting plates that vrumvrum makes have the new HU mounted high enough that you don't need to bend the bracket. Maybe someone with his plate can confirm this.
__________________
2007 LeMans Blue/2-Tone Gray Coupe w/MN6, 3LT, Z51, QX1, CC3, R8C Mods List
markcz is offline   Reply With Quote
Old 01-20-2006, 04:02 AM   #7
wiz1500
CF Senior Member
wiz1500's Avatar
Send a message via AIM to wiz1500
I have vrummvrumm's plate and trim ring the H.U. is still in the factory location so you do have to bend the bracket out of the way. I also had to remove the clip on the air duck. The alpine IVA-D310 just made it......
wiz1500 is offline   Reply With Quote
Old 01-20-2006, 08:54 AM   #8
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
Send a message via AIM to Metal Wulf
Quote:
Originally Posted by mechanix19
Jensen VM9510
your car should kick your ass for trying to put a jensen in it, it not fitting is your cars way of rejecting crap
Metal Wulf is offline   Reply With Quote
Old 01-20-2006, 11:26 AM   #9
rcs128
CF Senior Member
Quote:
LOL...
rcs128 is offline   Reply With Quote
Old 01-20-2006, 12:37 PM   #10
litnrod
CF Senior Member
litnrod's Avatar
litnrod is offline   Reply With Quote
Old 01-20-2006, 06:18 PM   #11
mechanix19
CF Senior Member
mechanix19's Avatar
Yea well affording a C5 when you are 21 is an accomplishment for me. I'm 24 now and still have my baby so I'm putting in what I can afford. Besides the stereo is made by Audiovox and after comparing this model to Pioneer and all your other expensive brands, I feel this one was just as good. The picture actually even looks better than your expensive brands. Anyway, after bending the bracket, moving all the wires, and cutting my hands in the process, I found out it was the TV antenna wire is what was keeping me from getting it in the last half inch. I tightened the screws as best I could and put everything back together. Turns out everything looks good and its solid. It sticks out a little bit but is only noticable if you put your face all the up to the edges, I can live with that. Thanks for all the help.
Old 01-20-2006, 08:56 PM   #12
mitch.smith
CF Senior Member
mitch.smith's Avatar
Good Luck
mitch.smith is offline   Reply With Quote
Reload this Page I can't get the stereo to fit?????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
I Love This Car!!!!! Corps Vet C6 Corvette General Discussion 9 10-16-2004 08:05 AM
Can't get anyone to remove cats?! Majestic43 C5 Tech 98 09-06-2003 12:59 AM
Things you want in a C6 ... Please add onto the list AP C6 Corvette General Discussion 73 09-23-2002 04:11 AM
Stereo setups in 77 or earlier. 77-4speed C3 Tech/Performance 27 07-31-2002 11:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
