Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2006, 11:53 PM   #1
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
Default Question about the Big 3
I am pulling my engine this weekend so I figured that would be a good time to run the wiring for the upgrade. Seems to me that it would be easier. My stereo project came to a halt when I decided to this first because I want to get some track times before adding all the extra weight of the equipment. In any event, the big 3 consists of what?
Run a line from the battery to the alternator and continue to use the existing alternator line right?
What ground lines do you replace? I know there is a ground strap on the drivers side that looks like a flat braided steel line. Is this one?
Also, I just noticed that there is one on the passenger side of the engine and another in front of the coolant tank I believe.
Thanks for the help!
Cajundude@EnglandGreen is offline   Reply With Quote
Old 01-18-2006, 11:20 PM   #2
Supporting Tuner
Nobody has done the big 3 lately?
Old 01-20-2006, 01:46 AM   #3
markcz
CF Senior Member
markcz's Avatar
The pics don't seem to be working, but this link should help you out a bit:
http://www.corvetteforum.com/techtip...=245&TopicID=1
__________________
2007 LeMans Blue/2-Tone Gray Coupe w/MN6, 3LT, Z51, QX1, CC3, R8C Mods List
markcz is offline   Reply With Quote
Old 01-20-2006, 02:33 PM   #4
fej
CF Senior Member
fej's Avatar
Wish the pics in that link still worked
Fej
fej is offline   Reply With Quote
Old 01-20-2006, 04:33 PM   #5
ShawnZR-1
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11
ShawnZR-1's Avatar
Send a message via MSN to ShawnZR-1
I'm of the mindset to leave the factory wiring alone and let it do what it was designed to do, run the stock car's electronics.
Simply run both power and ground wires from your battery to your aftermarket equipment. That way you know your amps will have all of the juice available and not worry about burning up any stock wiring.
ShawnZR-1 is offline   Reply With Quote
Old 01-20-2006, 06:00 PM   #6
fej
CF Senior Member
fej's Avatar
Shawn not sure I am clear on your meaning with running both power and ground to your amp. I know that running a ground from your amp all the way back to your battery would most likely induce some noise issues and possible ground problems to your system. Generally speaking you do not want the ground from your amp (or distribution block) to be more than about 12" long total from my car audio experience. Maybe with the C5 and its fiberglass etc this would be ok ... would not be the first time I was wrong
Fej
Old 01-20-2006, 11:20 PM   #7
GeorgeB
CF Senior Member
GeorgeB's Avatar
PICS
http://forums.corvetteforum.com/show...m_id=20&arch=1
GeorgeB is offline   Reply With Quote
Old 01-21-2006, 11:04 AM   #8
fej
CF Senior Member
fej's Avatar
Nice thanks
Fej
Reload this Page Question about the Big 3
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question About The Z06 Experience..... LowFlight C5 Z06 Discussion 24 08-24-2004 01:20 AM
have a question about the ATI prochargers inquire within fsuforever C5 Forced Induction/Nitrous 9 02-12-2004 07:30 PM
Big 3 Upgrade Questions Tony @ MPH Audio/Electronics 12 01-17-2004 06:34 PM
Question for the "Big Inch" and/or "Big Power" crowd 1969Vette383 C3 Tech/Performance 19 11-02-2003 10:24 PM
Question About GM High Tech Mag. jpee Drag Racing 68 02-05-2003 05:23 AM
Question about swirl removal, and wetsanding the paint? Z Factor Car Care Discussion 9 01-15-2003 10:46 PM
Again a question about the 1982...... Pete Z C3 Tech/Performance 10 03-10-2002 03:47 PM
Question about cruise-in 3 Racer National Events 11 01-08-2002 07:20 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
