Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-04-2005, 07:21 PM   #1
RainJ
CF Senior Member
RainJ's Avatar
Location: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Send a message via AIM to RainJ
Default CD Changer relocation in a C5
Alright, this should be easier than I am making it here.
Pulled the rear trim, removed the factory Changer and want to move it to one of the smaller bins.
Is there anyway to remove the threaded rivets in the rear tub?
How do you move those to a side bin and remount the CD changer?
No access to them from behind the tail lights -
No access from below either.
Im stumped and its pretty early in the game for me.
( have a 10" sub, forum built center bin box, amp, and wiring )
__________________
CLICK HERE: My Hurricane Katrina Pictures & Video
Endorsing Artist with CA Guitars: http://www.caguitars.com/
2000 Corvette Coupe---Black/Black---6 Speed
19/20 HRE 547, RKSport Hood, Long Tube Headers, Xpipe, Vararam, Borla Exhaust, FrameSavers/RockerRails, Eradispeed +1/+2 Rotors, Both Tops, Lowered, etc
1996 Corvette Coupe---Bright Aqua Metallic---Automatic
SOLD!!!!!
RainJ is offline   Reply With Quote
Old 12-04-2005, 07:44 PM   #2
RainJ
CF Senior Member
RainJ's Avatar
ok
best i can see - no access to the rear of whatever the threaded bolt/rivet is.
So the only answer is to cut it off at the surface, drill it out, and snap rivet it shut/sealed.
right?
Old 12-04-2005, 09:33 PM   #3
Blue Thunder
CF Senior Member
Cruise-In I Veteran
National Champs Gators 4 St. Jude '09
Blue Thunder's Avatar
Location: Welcome to the SEC...BCS champs 5 years running.
I will need to know the same thing soon...just got a sub box as well.
Blue Thunder is offline   Reply With Quote
Old 12-05-2005, 03:00 AM   #4
RainJ
CF Senior Member
RainJ's Avatar
best I can learn, the stock threaded bolts stay and do not block the sub box. Now how do folks remount the CD Changer in a side bin? (looking for pics of one installed there)
Test fit my sub box tonight and believe the Frost King and carpet must come out first. Might just go carpet and remove the sound dampening material.
Keep ya posted
Rain
Old 12-05-2005, 04:14 AM   #5
markcz
CF Senior Member
markcz's Avatar
My car didn't come with a changer, but I did have one for a while. I put it in the passenger side bin and just wedged some foam around it to keep it from bouncing around. It never skipped and the bin lid covered the cheesy looking foam.
markcz is offline   Reply With Quote
Old 12-05-2005, 08:26 PM   #6
WilliamCall
CF Senior Member
WilliamCall's Avatar
The threaded rivet is called a blind fastener. It works on the same principle as a pop rivet. The only way to remove them is to drill out the center. The back side of the fiberglass tub should have some metal straps that the blind fastener attaches to (hope the metal straps aren't bonded to the tub). I would drill out the blind fasteners, relocate the mounting brackets, drill new holes in the tub for the fasteners, and remount the brackets using pop rivets. In order for the pop rivets to hold the mounting brackets, there needs to be a metal strap on the back side of the tub. Otherwise, the pop rivets will pull through the fiberglass tub.
__________________
'04 Commemorative Edition coupe
cold air grills, Donaldson Blackwing, Euro T84 headlights, Goodridge SS brake hoses, Baer Eradi Speed brakes, Homelink sunvisor, ARH Headers, Z06 TI Exhaust, AVIC-F500BT, brake light camera
painted: hood blanket, windshield washer bottle, radiator expansion bottle, fuse box cover, and battery cover
WilliamCall is offline   Reply With Quote
Old 01-11-2006, 03:52 AM   #7
Stickman81
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10
Stickman81's Avatar
Quote:
Gotta luv it.
I was actually able to find the exact information I was looking for.
Thanks for the above info.
Stickman81 is offline   Reply With Quote
Reload this Page CD Changer relocation in a C5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
cd changer relocate VALL Audio/Electronics 9 04-07-2005 06:56 PM
Z06 Modifications vs. Horsepower ACELRNT C5 Z06 Discussion 18 05-11-2003 03:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
