Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-03-2005, 07:03 PM   #1
2K2 C5
CF Senior Member
Default How much power is hitting the C5 speakers?
I'm thinking of replacing the factory speakers with Infinity Kappas. How much power is hitting the speakers from the factory head unit? Is it enough to drive replacements without excessive distortion?
2K2 C5 is offline   Reply With Quote
Old 12-05-2005, 12:00 PM   #2
Prism911
CF Senior Member
You are not going to be able to drive any high power speakers well using the stock head unit.
Prism911 is offline   Reply With Quote
Old 12-05-2005, 01:38 PM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
Depends
If you just want to keep the factory head unit and get better sound, yes . You can replace both the 3.5" twiddler in the door and the rear speakers with the Infinity Kappas. Many have put in the 3.5" Kappas and loved the results for the little $
If you want to put like a 6.5" Kappa set in the doors, no . The 8" woofer has it's own amp. The head unit frequencies going to the twiddlers will not give out much (if any) bass.
knewblewkorvette is offline   Reply With Quote
Old 12-05-2005, 10:43 PM   #4
2K2 C5
CF Senior Member
Sounds promising. Specifically, what I had in mind was the 3.5 two-ways in the doors, the 6.5 two-ways in the back and a 12 in a stealth type box with a 350 watt alpine amp tucked away, hooked to the hu with a pac. I was considering the alpine because the dimensions would allow me to put it into the center storage space just starboard of the cd changer. I just hated to go to all that work and find out I couldn't drive the speakers. Thanks for the input.
Old 12-06-2005, 05:58 PM   #5
knewblewkorvette
CF Senior Member
that would work great...but...if the amp and CD changer are in the rear center compartment, where is the 12" sub going
Old 12-07-2005, 10:02 PM   #6
2K2 C5
CF Senior Member
I was planning on allowing the sub to protrude up from the floor and designing a box based on the dimensions of the equipment after I gather it together. If there's still no room in the rear center, the amp I've got in mind will find under my manual passenger seat and I'll have to rethink relocating the cd changer.
Reload this Page How much power is hitting the C5 speakers?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 Vert Review with S2K Comparison: Warning---Epic length! S2K C6 Corvette General Discussion 47 02-27-2005 01:08 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
