Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-11-2005, 02:03 AM   #1
PolishDude
CF Senior Member
PolishDude's Avatar
Default need audio experts, help with amp what does bp mean?
i have a cadence 6 channel amp. This amp will allow you to have surround sound in your car, channels 1 and 2 are the front speakers, 3 and 4 are the rear, 5 is center and 6 is sub. Anyways 1 and 2 have a crossover mode of hp or full and then the knob to adjust the hp channel 5 is the same. Channel 6 has just crossover mode of lp or full then the knob to adjust the lp frequency, but what puzzles me is channels 3 and 4. You can select between hp, bp, and full and has a hp and a lp knob. What does bp mean? I am assuming that if u put it on bp you can control the lowest frequency the speaker gets as well as the highest but am not sure.
Cliffnotes: what does bp mean when i have a selection of crossover settings of hp, bp or full
PolishDude is offline   Reply With Quote
Old 10-11-2005, 02:46 AM   #2
aeronautica86
CF Senior Member
aeronautica86's Avatar
Send a message via AIM to aeronautica86
I'm pretty sure that these are refering to crossovers:
hp - high pass crossover
lp - low pass crossover
bp - band pass crossover
aeronautica86 is offline   Reply With Quote
Old 10-11-2005, 09:07 AM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
knewblewkorvette is online now   Reply With Quote
Old 10-11-2005, 01:33 PM   #4
PolishDude
CF Senior Member
PolishDude's Avatar
whats a band pass crossover, never heard of that one, i know their are bandpass boxs does it have anything to do with that? if so why would it be on the 3 and 4 channel rather then on the 6th channel that is made for a sub that already has bass boost boost frequency, subsonic and low pass crossover settings
Old 10-11-2005, 04:52 PM   #5
1COOLPC
CF Senior Member
1COOLPC's Avatar
Yup, band pass. Cut the lows and the highs out of the rear speaker. That helps with better front imaging. I always do something to trim the highs down from the rear, Around 8K is usually good.
1COOLPC is offline   Reply With Quote
Old 10-11-2005, 05:30 PM   #6
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
so... now that you have your answer.... what are you going to use to get 5.1 to the amp? Tell us more about your project
scott_fx is offline   Reply With Quote
Old 10-12-2005, 02:19 AM   #7
PolishDude
CF Senior Member
PolishDude's Avatar
i wish i had some baller project in mind but for now i am just going to use it to power the fronts and rears and the sub, no center speaker nor any sort 5.1 project. I am about to graduate college, maybe once i get done with college and have a good paying job i can use the amp to its full potential, the amp is def a beast
Reload this Page need audio experts, help with amp what does bp mean?
Tags
amplifier, bandpass, bp, hign, low, mean, meanamp, pass, put, stereo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
