Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-21-2005, 12:37 PM   #1
spdnman
CF Senior Member
spdnman's Avatar
Default Doors Rattle with Speakers
What do you guys do to stop your doors / speaker grills from ratlling with aftermarket speakers/amps? I've tried dynamat extreme, but not good enough. Would a subwoofer in the trunk help? Thanks.
__________________
WRECKED...I miss this car!!!!! 224/224 114 Cam, Kooks 1 3/4, Hi Flow Cats, LS6 Intake, 3.90's, PT 2400, Z06 Exhaust, K&N, 160 Thermostat, Kool Sox, Tunnel Plate, Z06 Springs, Bilstein Shocks, Hotchkis Sway Bars, Eradispeeds, Toyos, V1, Alpine, Phoenix Gold Amp, 12" Image Dynamics Sub/Subthump, MB Quarts, Dynamat, Worked Tranny and Cooler, etc. 370 rwhp & 331 torque 12.3 @ 113 on 22 psi Toyo's.
spdnman is offline   Reply With Quote
Old 08-21-2005, 02:19 PM   #2
Steve Germany
CF Senior Member
Steve Germany's Avatar
I use the stick-on household door hollow tube insolation around the speaker hole and new door securing pins whenever I finalize the install in the doors.
Steve Germany is offline   Reply With Quote
Old 08-21-2005, 06:25 PM   #3
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Support Corvetteforum!
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
Rattle Pad
Cajundude@EnglandGreen is offline   Reply With Quote
Old 08-23-2005, 07:16 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
getting a sub and using the correct x-over frequencies help too
scott_fx is offline   Reply With Quote
Old 08-23-2005, 07:51 PM   #5
spdnman
CF Senior Member
spdnman's Avatar
Quote:
Any suggestions on a decent sub? Hoefully under $400. Thanks again.
__________________
Old 08-23-2005, 08:01 PM   #6
Supporting Tuner
I'm in the process of putting in two JL Audio 10W6V2 subs. I hear they are the chit.
Old 08-23-2005, 08:35 PM   #7
spdnman
CF Senior Member
spdnman's Avatar
Quote:
Do you have a picture of the subs?
Old 08-23-2005, 08:43 PM   #8
scott_fx
CF Senior Member
scott_fx's Avatar
check out the w7 for $350
http://forums.corvetteforum.com/show...76&forum_id=20
Old 08-23-2005, 11:05 PM   #9
Supporting Tuner
Quote:
I'm still building the boxes right now so no, not in my car. You can see the sub at www.jlaudio.com. Here is a pic of my most recent progress:
You can see the first pics here.
Old 08-25-2005, 04:50 AM   #10
BigDaveC5
CF Senior Member
BigDaveC5's Avatar
Send a message via AIM to BigDaveC5
that looks awesome
BigDaveC5 is offline   Reply With Quote
Old 08-25-2005, 04:51 AM   #11
BigDaveC5
CF Senior Member
BigDaveC5's Avatar
that box looks awesome, nice work
Old 08-25-2005, 07:42 AM   #12
Supporting Tuner
Thanks! Once I am done with the first one I should be able to do the second one A LOT quicker since I now know what I want, ummm, hopefully.
Old 08-25-2005, 09:25 AM   #13
spdnman
CF Senior Member
spdnman's Avatar
Maybe you can charge me and build a set for me? Let me know.
__________________
Old 08-25-2005, 10:03 AM   #14
Supporting Tuner
Well, lemme see how it all comes out first, finishing, etc. And of course, how it sounds. Since I have no fiberglass experience I am probably using way more materials than I should and it takes me A LOT of time.
Old 08-25-2005, 12:13 PM   #15
Prism911
CF Senior Member
If you aren't like Cajundude (trying to collapse your skull via a high sound pressure level ) then a box from Subthump and a JLAudio 10w3v2 sub will probably serve your purpose.
Prism911 is offline   Reply With Quote
Old 08-25-2005, 12:21 PM   #16
Supporting Tuner
Quote:
Actually I have no idea what this system will do. I haven't installed a big system since 1988. I'm sure technology has changed since then. I am trying to set up a system for sound quality and not spl. That is why I went with the 10w6s instead of the 10w7s. I tend to go overboard with things, especially if I do the stuff myself. I take pride in something if I've done it and it looks good.
Here is what will be running with them:
Head unit (undecided)
(2) JL Audio 10w6v2 subs powered by JL 1000/1
Focal 165K2P components powered by JL 300/2
Lotsa big wires
Alumapro 15 Farad cap
Old 08-25-2005, 01:13 PM   #17
Prism911
CF Senior Member
With all the enclosure work you've been doing, I assumed you were preparing a show car which needs to kick @ss more than a "standard" listening-while-driving setup would.
For my coupe I went for:
Alpine CDA-9813 head unit
Alpine MRD-M605 sub amp powering a JLAudio 10w3v2-D2 sub.
Alpine MRV-f345 component amp powering JLAudio VR525-CXi (rear) and XR650-CSi (front) satellites.
6 guage power and ground, 16 guage speaker wire.
Fatmat sound deadening, with an extra layer of Frost King in the doors.
I have not tried it out yet with the top off.. my driving is limited until I get the amp rack complete. But with the top on, it's almost enough to make your ears bleed. After a certain volume level it all turns to noise as far as the brain is concerned.
The single sub is enough to make the car vibrate. I may later try out a 12 inch one in order to get a little deeper base but I can't even image what 2 subs would be like.
Old 08-25-2005, 01:22 PM   #18
Supporting Tuner
Nope, no stereo show car, never been in one. Yep, I tend to go overboard. You haven't seen the half of it. I ripped the interior completely out and used 160 sq. ft. of deadener as well. After the deadening I wired everything for the new upcoming system before I put the interior back together. I used Stinger 0 AWG for the power, 0 AWG for the ground, Stinger Dream interconnects, 12 gauge remote turn on for the amps, and 80 feet of Stinger HPM twisted speaker wire.
BTW, nice system you have! I guess if the hatch blows off the back of the car when I turn it on, I'll rip it out and sell it.
Old 08-25-2005, 01:29 PM   #19
Supporting Tuner
Ooohhhh, forgot to mention one thing. I WILL NOT be able to use my top latches with this setup. When test fitting in the beginning I could not find an angle that looked good with the mdf rings that I made and still be able to use the latches. I quit for the day and thought about it and decided that the recessed sub look was more important to me than being able to use the top latches. The latches could be used if I didn't flush mount the sub. I can however fit the top in the back still so I on the rare occasions that I take the top off I will probably rig something up and have the top in a bag or just leave it at home. I usually don't drive in the rain much.
Old 08-25-2005, 02:16 PM   #20
Prism911
CF Senior Member
Now THAT is what I call overkill!
Targa Top Storage Bag
Make sure to video tape your initial run of the completed system. You may be the first member of the Flying Hatch Club!
Reload this Page Doors Rattle with Speakers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 04:33 AM
Surely the door speakers should be for bass ? (1988 C4) Stingraynut Audio/Electronics 9 05-27-2003 03:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
