Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-19-2005, 10:36 AM   #1
hz900
CF Senior Member
hz900's Avatar
Default Do I need a higher amp alternator?
I need a new alternator and am about to put in two amps in my car. First is a Pioneer 760 watt amp and the second is a Pioneer 200 watt amp. I was thinking the stocker would do, but I wanted to check to make sure, if I don't need it I'm not going to spend the extra money just because.
I have a '90 model and the stock alt. is 105 amps.
hz900 is offline   Reply With Quote
Old 08-19-2005, 12:22 PM   #2
Steve Germany
CF Senior Member
Steve Germany's Avatar
You did not provide much information but the short answer is no - not now. After you have it set up and power presents a problem then readdress the issue.
Steve Germany is offline   Reply With Quote
Old 08-19-2005, 12:34 PM   #3
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
Send a message via AIM to Metal Wulf
no alt needed, but I would do the big 3.
Metal Wulf is offline   Reply With Quote
Old 08-19-2005, 02:33 PM   #4
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
knewblewkorvette is offline   Reply With Quote
Old 08-24-2005, 12:44 PM   #5
Cajundude@EnglandGreen
Supporting Tuner
Houston Events Coordinator
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
Cajundude@EnglandGreen's Avatar
Location: ========= Houston, Texas www.englandgreen.com ============== Necessary Evil™ __ 281.464.2800
How many amps is a stock 02 alternator?
Cajundude@EnglandGreen is online now   Reply With Quote
Reload this Page Do I need a higher amp alternator?
Tags
105, 1990, alternator, amp, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
do i need to upgrade alternator if changing to electric fans?? Gary79 C3 Tech/Performance 9 09-10-2003 01:07 AM
Capacitors for the amp or bigger alternator? Nathan Plemons Audio/Electronics 23 12-10-2002 02:09 PM
How do I get rid of "Radio Noise" madmaxgt C3 Tech/Performance 21 05-02-2002 11:12 PM
150 Amp alternator 8T1-7T9 BIONIC VETTE C3 Tech/Performance 20 01-17-2002 04:15 AM
How do you find a short? nobodyunknown C4 Tech/Performance 23 01-12-2002 01:28 AM
Alternator Question? CG77VETTE C4 Tech/Performance 10 12-22-2001 09:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
