Sponsored by: DashLynx
C6 FAQ audio - look here first!
Old 07-30-2005, 06:22 PM
Steve Germany
Steve Germany's Avatar
Default C6 FAQ audio - look here first!
Responsibility for maintenance of the C6 Audio FAQ is being pased along from Steve Germany to TheKomoman. See this thread for future updates:
http://forums.corvetteforum.com/show....php?t=1844206
:cheers
savewave
THE NEW C6 AUDIO FAQ!
Since this thread was started there have been lots of great work done to upgrade the C6 audio. The original thread went to bit heaven and it is being rebuilt. Here are the new and improved links and threads...
I'd like to ackowledge all of the effort TheKomoman has put into making sure that the best tips are included in this sticky. [B]Thanks Dan![B/]
Thekomoman's link - CAN I ADD FACTORY NAV TO MY C6 - Great write up!
http://www.lazyassgeek.com/?page_id=50
2005 c6 Nav firmware upgrade - fixes FM static and play MP3s!
http://forums.corvetteforum.com/show...&postcount=152
TSB on the MP3 firmware upgrade and FM Static fix for '05 C6s
http://forums.corvetteforum.com/show....php?t=1254624
Quick And Easy CD Ripping For The Corvette-How to step by step
http://forums.corvetteforum.com/show....php?t=1496476
C6 Audio Options (CMB13)
http://forums.corvetteforum.com/show....php?t=1474566
C6 Audio Low level pin outs
http://forums.corvetteforum.com/show....php?t=1496904
GM aux input coming!
http://forums.corvetteforum.com/show...ht=mp3+upgrade
Cracking the NAV - what we know now
http://forums.corvetteforum.com/show....php?t=1555098
Help Crack the NAV pin codes
Blazer's Console removal and Step by Step Aux Input Added to Nav Instructions
http://forums.corvetteforum.com/show...p?p=1551172269
How to make your own subwoofer template in order to replace the Bose thumper
http://forums.corvetteforum.com/show....php?t=1539178
C6 (C5?) Door clip GM part numbers
http://forums.corvetteforum.com/show....php?t=1654485
How to reinstall the door panels
http://forums.corvetteforum.com/show...post1551623833
C6 Door mounting plates to replace Bose 10in
http://forums.corvetteforum.com/show....php?t=1487774
Replacing the stock speakers
http://forums.corvetteforum.com/showthread.php?t=927166
http://www.bcae1.com/
Harness for the C6 Speakers - Circut City
http://forums.corvetteforum.com/show....php?t=1658056
Center Channel speaker Removal (or replacement - why?)
http://forums.corvetteforum.com/show....php?t=1496569
NAV UPGRADES
How to Bypass the PAC OEM GM24 line level adaptor and eliminate the need for a JL Cleansweep
http://forums.corvetteforum.com/show....php?t=1489160
New much better instructions on how to bypass the PAC OEM GM-24 to get true low level signals from the NAV head unit (TheKomoman)
http://forums.corvetteforum.com/show....php?t=1496764
C6 Vert Audio upgrades!
TheKomoman and PipeDreams
http://forums.corvetteforum.com/show....php?t=1471466
http://forums.corvetteforum.com/show....php?t=1355644
CMB13's Write up
http://forums.corvetteforum.com/show....php?t=1355648
C6 Convertible audio upgrade
http://forums.corvetteforum.com/show...ight=nav+audio
Add on Components
How convert your sat radio from XM to Sirius
http://forums.corvetteforum.com/show....php?t=1733829
How to add an AUX input into your XM radio (IPOD)
http://forums.corvetteforum.com/show....php?t=1748480
USA SPEC PAC-11 (Vette) with XM install
http://forums.corvetteforum.com/show...post1559507678
http://forums.corvetteforum.com/show....php?t=1518095
How to dim the lights on an aftermarker HU
http://forums.corvetteforum.com/show...74&postcount=6
Pioneer AVIC D2
AVN6600 Full Write-up in a C6!!
http://forums.corvetteforum.com/show....php?t=1490531
USA spec XM radio to IPOD - Best interface for the C6 vette
http://forums.corvetteforum.com/show...post1559106048
Neucleus-X2i - C6 XM to IPOD
http://forums.corvetteforum.com/show....php?t=1377824
Parrot Bluetooth adaptor install Nice write up!
http://forums.corvetteforum.com/show...1&page=1&pp=20
NEW - Plug and play Bluetoothhttp://forums.corvetteforum.com/show....php?t=1600739
PDF of Parrot Bluetooth install
http://mysite.verizon.net/vzev28k6/s...oothHow-To.pdf
IPOD install
http://forums.corvetteforum.com/show...post1553872918
iPod / AUX adapter:
http://forums.corvetteforum.com/show...st15503161 49
XM MP3 aux install on NAV unit -- DIY:
http://forums.corvetteforum.com/show...0&forum_id=101
Add AUX to NAV... DIY! :
[utl]http://forums.corvetteforum.com/showthread.php?t=1121425&forum_id=74[/url]
C6 XM install
http://forums.corvetteforum.com/show....php?t=1087750
Car Personal Computer:
http://forums.corvetteforum.com/showthread.php?t=983973
http://forums.corvetteforum.com/show...7&page=1&pp=20
http://forums.corvetteforum.com/show....php?t=1476172
AUX input mod:
http://www.pqtsi.com/sedona/vetmp3.pdf
Can I put a stock 05 Nav unit into a '06?
http://forums.corvetteforum.com/show....php?t=1693230
DVD NAV aftermarket install:
http://forums.corvetteforum.com/show....php?t=1041187
OUTSTANDING!! Complete writeup w/pics Pioneer AVIC D2 w/aftermarket speakers and amp in a 2005 C6
Problems
No sound from radio:
http://forums.corvetteforum.com/showthread.php?t=936157
Dead stereo:
http://forums.corvetteforum.com/showthread.php?t=914846
Automatic Volume Control
Left channel cuts out when touching DIC buttons:
http://forums.corvetteforum.com/showthread.php?t=940392
1SA radio and interface cables for aftermarket radios:
http://forums.corvetteforum.com/showthread.php?t=926949
DIY Speaker adaptors
Show your C6 audio upgrade!
Where's all the pics?
http://forums.corvetteforum.com/show....php?t=1478404
http://www.icixsound.com/vb/showthre...8&page=1&pp=10
Wiz1500 here
http://forums.corvetteforum.com/show....php?t=1283185
http://forums.corvetteforum.com/show....php?t=1373431
Fiberglass - DIY
http://www.rtol.net/scornell/HowTo.htm
http://www.caraudiohelp.com/how_to_f...fiberglass.htm
http://web.njit.edu/~cas1383/proj/main/
http://www.carstereo.com/help/Articles.cfm?id=62
Using Foam
http://www.mp3car.com/vbulletin/showthread.php?t=83348
Old 07-31-2005, 09:11 AM
docrings1
docrings1's Avatar
C6 FAQ Master
I have put this "Radio FAQ" thread in the main "C6 FAQ" under the C6 general discussion sticky threads...
Good job!
Old 08-02-2005, 12:15 AM
bogus
bogus's Avatar
This needs to be a sticky.
Old 08-02-2005, 02:40 PM
scott_fx
scott_fx's Avatar
maybe you could post all this info in the thread instead of links to it. I've had a handfull of threads get eaten up in the archives. I'd hate to see al the great info get lost.
Nice work though
Old 08-02-2005, 04:56 PM
bogus
bogus's Avatar
Ask and ye shall recieve!
Great to see this a sticky!
Old 08-07-2005, 12:37 PM
docrings1
docrings1's Avatar
C6 FAQ Master
Bad links in the 1SB section, the problem is the little dots...you must have "copied and pasted" the dots, too, from another location, so now the URL links are broken:
Bad section below:
Add AUX to NAV... DIY! : http://forums.corvetteforum.com/sho...hp?p=1551172269
Pioneer AVIC-D1 NAV / DVD / IPOD unit: http://forums.corvetteforum.com/sho...805&forum_id=74
XM MP3 aux install on NAV unit -- DIY: http://forums.corvetteforum.com/sho...50&forum_id=101
Pioneer AVIC install: http://forums.corvetteforum.com/sho...776&forum_id=74
Console, door panel, dash removal DIY: http://forums.corvetteforum.com/sho...809&forum_id=20
iPod / AUX adapter: http://forums.corvetteforum.com/sho...ost15503161 49
Old 08-08-2005, 07:34 PM
Steve Germany
Thanks! Fixed or eliminated.
Old 12-13-2005, 10:54 AM
ShockerRacing
ShockerRacing's Avatar
None of the links are working! I am trying to find out some info about what exactly is needed to wire in an amplifier for a Subwoofer on a 1sa car. Can anyone give me some details?
Old 09-05-2006, 12:26 AM
0Audio Dave
Former Vendor
Audio Dave's Avatar
Location: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
Here is a link to a full, detailed write-up on a Navigation head unit install in a 2006 Coupe, 1SA package. Hope this helps!!
Old 09-05-2006, 08:03 AM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
Nice job on the rebuild Steve!
Old 09-11-2006, 01:10 PM
cmb13
cmb13's Avatar
Old 09-12-2006, 12:17 PM
TheKomoman
TheKomoman's Avatar
St Jude Donor '13
Hey Steve... a guy did a nice write-up and posted it over in General about how to create an MP3 CD that works in the C6. I think it's worth adding to the list:
Old 09-14-2006, 10:46 PM
TooManyIDs
TooManyIDs's Avatar
Bad link ....
http://forums.corvetteforum.com/show...09&forum_id=20
Old 09-17-2006, 07:17 PM
Steve Germany
Gone! looking for a replacement!
Old 11-25-2006, 04:07 PM
dbdragger
dbdragger's Avatar
Audio Daves write up on the c6 eclipse 6600 install greatly helped me on a full install I did in my best friends 06 Z06, if def saved me alot of time, that I didnt have to spare. Only had 3 days to do the full car. Again thanks. I signed up for this forum to to say thank you.
Shawn Fleming
Old 12-03-2006, 06:54 PM
Steve Germany
Old 12-24-2006, 07:17 PM
SavannahVette13
SavannahVette13's Avatar
i was wondering if there is a way to play dvds on my 07 stock nav?
To C6 FAQ audio - look here first!
Old 12-25-2006, 10:43 AM
Steve Germany
No - there is no way with the stock HU.
Corrected - there is a group out of NY that does it but the screen quality is still questionable and expensive.
Old 06-03-2007, 04:59 PM
crazy4rc
crazy4rc's Avatar
Default Still don't know which way to go....
I have read ALL these FAQs. There is some great info in here! Thanks to all that have taken the time to post their work and research. I still have a question on the best way to go.
I have a 2007 Coupe with NAV and Onstar. I want to keep the HU and have everything work as stock, but replace the Bose amp and speakers.
I have read conflicting info on the PAC AOEM-GM24 (good or bad?), tapping into the pre-amp outputs directly (no interface device), JL Cleansweep (pricey but works good), and even more options that are not mentioned here, like this interface device (which I used in my last vett 2002 Z06): AudioLink.
So from what I gather, I need to leave all the Bose amps and wiring in place to keep the functionallity stock, but can pull out the speakers. then (some how) tap into the outputs and go into my amps.
So what's the best way (best sound quality), to tap in and keep all stock functionality? Anyone?
Old 06-19-2007, 02:43 PM
vaelon2007
vaelon2007's Avatar
Default bad link
The link http://www.discountave.net/adpacmoauine.html for the harness is no longer a working domain. Where else can I buy this harness?
Quick Reply: C6 FAQ audio - look here first!
