Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2005, 11:50 AM   #1
Larry_Yerton
CF Senior Member
Larry_Yerton's Avatar
Default How do I know if....
How do I know if I have a cd-changer wiring harness? I have a '03 coupe that did not come with a cd changer so chances are it doesn't have one correct?
If it does have one would it be pluged into the head unit and tucked under the dash or would the wires be ran back to the rear storage areas?
Thanks.
Larry
Larry_Yerton is offline   Reply With Quote
Old 07-17-2005, 12:39 PM   #2
LarryW
CF Senior Member
LarryW's Avatar
Larry,
Two places to check if your Vette was pre-wired from the factory for a CD-changer harness:
1. The rear trunk area; I believe if it's pre-wired, the cable will be located beneath the carpeting (not sure where though maybe someone else can chime in here ). I *believe* the changer is mounted in the middle of the trunk at the factory so this might be a place to look...the CD-changer harness is routed along the passenger side of the vehicle.
2. The CD-changer harness hooks into the factory head unit via two "port" plugs located in the passenger footwell area (lower right-hand corner, see this thread for pics). If the plugs are taped up and not connected to anything, your Vette is not pre-wired with a CD-changer harness
LarryW is offline   Reply With Quote
Old 07-17-2005, 01:11 PM   #3
Larry_Yerton
CF Senior Member
Thanks Larry.
Your info plus that thread gave me the info I needed. I'm adding a DVD and will be getting a GM10-AUX converter but needed to know if I also needed to get the COR-HAR wiring harness.
Old 07-17-2005, 02:55 PM   #4
LarryW
CF Senior Member
LarryW's Avatar
Larry,
You're welcome
Please be sure to post pics of your DVD installation; especially if it's one of those navigation setups
Reload this Page How do I know if....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do I know if C4 has Z07 package? BigTexas C4 General Discussion 27 10-12-2004 06:20 PM
How do I know if my secondaries are working? virtue4u C3 Tech/Performance 10 10-29-2001 10:36 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
