Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2005, 10:14 AM   #1
foundvettelifeisgood
CF Senior Member
Default Cutting the C3 bezel for DIN
What's the best tool/technique?
foundvettelifeisgood is offline   Reply With Quote
Old 07-16-2005, 10:20 AM   #2
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
Send a message via AIM to Metal Wulf
buy a repro that's already been cut
Metal Wulf is offline   Reply With Quote
Old 07-16-2005, 10:36 AM   #3
CF Senior Member
I believe they are $200 plus shipping.
Old 07-16-2005, 11:58 AM   #4
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
I use an air saw with a fine tooth blade or a dremel tool. A hand saw with a fine blade will work also. I recommend that you mark the piece before cutting, then cut to about 1/16th from the mark. Then use a fine file to bring your cut all the way to the mark. You will end up with a much cleaner finish on your cuts.
EatRice is offline   Reply With Quote
Old 07-16-2005, 09:28 PM   #5
Motor City Vette
CF Senior Member
Motor City Vette's Avatar
I used a carbon fiber cutting blade (actaully, quite a few) in my Dremel...worked fine.
__________________
1970 Convertible, #'s Matching, L46 (350/350), Muncie 4-Speed, Centerforce II Dual-Friction clutch, Hurst Competition Plus Shifter, Kenwood Excelon XM head-unit, Hooker Super Competition Headers and Sidepipes, VBP 330-lb Composite Rear Spring, Pertronix Flamethrower II Ignitor, Pertronix Flamethrower II Coil, Cam
Motor City Vette is offline   Reply With Quote
Old 07-17-2005, 06:41 AM   #6
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
Send a message via AIM to diviniti
If you have a dremel, you can also stuff a "Roto Zip" bit in it.
I usually get a few packs of (Metal) Rotozip bits. Work great for cutting plastic/metal/fiberglass etc..
diviniti is offline   Reply With Quote
Old 07-17-2005, 02:27 PM   #7
Metal Wulf
CF Senior Member
Metal Wulf's Avatar
use the trim plate as a template for the cut, then a dremel will be your best bet.
Reload this Page Cutting the C3 bezel for DIN
Tags
bezel, c3
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cutting the C3 bezel for DIN foundvettelifeisgood C3 General 12 07-18-2005 08:06 AM
F/S: C3 Hi-Pwr AM/FM/Cass Stereo (NIB) Perfect fit - No Cutting Dash! etech152 C3 Parts for Sale/Wanted 33 04-22-2005 10:25 PM
[1973] converting car radio area to DIN style Mike Mercury C3 Tech/Performance 21 06-05-2003 11:28 PM
C3 aftermarket Stereo 7SILVER8 C3 Tech/Performance 12 04-22-2003 10:49 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
