Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-14-2005, 11:40 PM   #1
Motor City Vette
CF Senior Member
Motor City Vette's Avatar
Default Need some troubleshooting help for my subwoofer installation
Okay, here's the deal. I purchased a very inexpensive powered subwoofer (Bazooka TA850) to get a little extra bass for my tunes. I'm not looking for anything "booming" or ear-splitting loud, I just wanted something so I can hear my tunes above the wind noise and sidepipes in my convertible, nothing more. I hooked it up to my head unit (Sony CDX-F7700), but I'm not getting any sound out of the Bazooka. Here's the lowdown...
* Grounded the ground-wire to a bolt in the chassis.
* Ran the power-wire from the battery (as stated in the instructions, run directly from the positive terminal post of battery, not from a fuse point or anywhere else).
* Connected the subwoofer from the back of the head-unit (using the supplied pre-outs) to the Bazooka tube using a Scoche 17 foot RCA patch cable.
* I ensured the yellow quick-disconnect jumper loop was plugged in.
* Inserted the fuse into the appropriate spot on the power wire
I turned on the power to my car and the radio was playing fine...all speakers were working (2 front 4x6 speakers and 2 rear 6x9 speakers) except for the Bazooka (nothing). I checked the settings on my head-unit and the Sub setting was turned on and showed that it should be getting something.
Any ideas???
Thanks in advance!
__________________
1970 Convertible, #'s Matching, L46 (350/350), Muncie 4-Speed, Centerforce II Dual-Friction clutch, Hurst Competition Plus Shifter, Kenwood Excelon XM head-unit, Hooker Super Competition Headers and Sidepipes, VBP 330-lb Composite Rear Spring, Pertronix Flamethrower II Ignitor, Pertronix Flamethrower II Coil, Cam
Motor City Vette is offline   Reply With Quote
Old 07-15-2005, 12:17 AM   #2
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
Sounds like you did not connect the turn on wire. There should be a wire going to your head unit along with the RCA cables. This wire actually turns the amp on inside of the bazooka tube. The larger power wire supplies the power once the amp is on.
EatRice is offline   Reply With Quote
Old 07-15-2005, 12:57 AM   #3
kh24
CF Senior Member
kh24's Avatar
Send a message via AIM to kh24
Quote:
Yup sounds like it. just run a small wire from the amps remote terminal and splice it into the sony's blue with white stripe wire and then you should be all squared away
__________________
2002 Torch Red/Mod Red Z06
2 X package
472.3rwhp 422.3rwtrq through 4.10s and full exhaust with mufflers
Stock bottom end 346ci NA
10.69@128.59MPH
Best 60ft. 1.42 on et streets
kh24 is offline   Reply With Quote
Old 07-15-2005, 04:25 PM   #4
Bakersfield
CF Senior Member
Bakersfield's Avatar
Another quickie test would be to jumper between the power lead and the amp turn on lead. Just be careful not to short anything out.
Bakersfield is offline   Reply With Quote
Old 07-16-2005, 01:10 PM   #5
Motor City Vette
CF Senior Member
Thanks! I'll give it a shot this afternoon.
Old 07-16-2005, 05:09 PM   #6
Motor City Vette
CF Senior Member
Quote:
I just tried this (hooking up the orange remote wire to the Sony blue-white AMP wire) and still no luck. I double-checked all the connections and they all seem fine. I also checked the fuse on the Bazooka's main power wire and it seems okay.
Any other ideas???
Thanks.
Old 07-16-2005, 05:22 PM   #7
QuikZilver
CF Senior Member
QuikZilver's Avatar
Like the others have said, you should have the blue wire from the Bazooka tube connected to a remote turn on lead. You should have the power wire, turn on lead, ground and RCA's all hooked up to the Bazooka. Also, check the gains on the Bazooka. You may have it turned all the way down. I can't think of anything else. I've had Bazooka tubes in a number of my vehicles (2 powered tubes) and that is all you need to do.
QuikZilver is offline   Reply With Quote
Old 07-16-2005, 09:21 PM   #8
Motor City Vette
CF Senior Member
I think this thing is deffective. I've got all the wires connected, including the amp power turn-on wire, but still nothing. I've tried everything. Man, how frustrating. Maybe I should just return the thing and get something else.
Old 07-16-2005, 11:49 PM   #9
Motor City Vette
CF Senior Member
Nevermind...got it working...I changed grounds. Apparently the ground I originally had it connected to wasn't good (the bolt was quite dirty, etc.). I changed to a ground that was free of paint and grime and now it's working. Thanks for the suggestion onaqwst!
Old 07-17-2005, 06:39 AM   #10
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
Send a message via AIM to diviniti
Phew... I thought I was gunna have to offer to come fix it for you.
j/k if any locals ever need any help I am always willing to jump in. I just require Food+Drink.
diviniti is offline   Reply With Quote
Reload this Page Need some troubleshooting help for my subwoofer installation
Tags
2005, bazooka, corvette, install, installation, manual, powered, shooting, speaker, subwoofer, ta850, trouble, troubleshoot, troubleshooting, tube
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
