Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Audio/Electronics
Stereo System Installation Info, Amplifiers, Subwoofers, Radar Detectors, Police Scanners, and CB Radios for the Corvette Sponsored by
Optima Batteries
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2005, 09:37 PM   #1
Spawn22
CF Senior Member
Spawn22's Avatar
Default What is needed to install new radio headset?
DO I need to run all new wires from the stock Bose system to an aftermarket brand head set and speakers?
Spawn22 is offline   Reply With Quote
Old 07-10-2005, 12:26 AM   #2
Bakersfield
CF Senior Member
Bakersfield's Avatar
The door speakers have amps built into them. You will probably damage them if you wire them up to the output of the new head unit. If I were you, and this is what I did, spend an extra 100 bucks and replace the door speakers and run new wiring. The stock wires are like 22 gauge and if you are pumping out 30 or more watts to a speaker, you should have 16 gauge minimum. I like to use lamp cord because it combines both leads and the gauge is large enough to handle the power and it is cheap and can be found at a hardware store, and it is sold by the foot. Good luck....
Bakersfield is offline   Reply With Quote
Old 07-10-2005, 12:29 AM   #3
GrayC5
CF Senior Member
GrayC5's Avatar
The folks over in the Audio/Electronics section of the Forum may be in a better position to help you on this one. Good luck.
GrayC5 is offline   Reply With Quote
Old 07-10-2005, 09:30 AM   #4
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
Quote:
only the door subs have an amp, the 3 1/2" door speakers do not.
RPOZ4Z is offline   Reply With Quote
Old 07-10-2005, 12:26 PM   #5
Spawn22
CF Senior Member
Spawn22's Avatar
So I will have to only replace the door wires with the subs? The rear speakers should be fine with the factory wires for the new speakers?
Old 07-10-2005, 08:25 PM   #6
Bakersfield
CF Senior Member
The problem you are going to run into is that the factory speaker wires go into a connector that plugs into the stock stereo. If you go with an after market head unit, you will have to identify the speaker wires that go to this connector and cut them off to connect them to the new head unit. There may be an adapter available, but that will be a little costly. If you are running 45 watts or so to each speaker, the small gauge factory wires are not really big enough to handle the power. That is why stereo shops routinely install new wiring to the speakers. It is not hard to run new wiring, there are several write ups over in the audio section of this forum that explain how to remove door panels, seats, and carpet to allow you to hide the wiring. If you cut corners on your installation, it will cause you many problems down the road. Do it right the first time. Good luck….Dwayne
Reload this Page What is needed to install new radio headset?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ipod CA Vette C5 Tech 26 03-14-2004 07:18 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
