Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2005, 11:06 PM   #1
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
Default how to adhere carpet to speaker box?
what is the best way to glue down carpeting to wood sub box? I have some liquid nails, would that do the trick? is there something better?
scott_fx is offline   Reply With Quote
Old 06-02-2005, 11:51 PM   #2
Pipedreams
CF Senior Member
St. Jude Donor '06-'07
Quote:
3M Hi Strength 90 is the correct poroduct
Pipedreams is offline   Reply With Quote
Old 06-03-2005, 12:03 AM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
knewblewkorvette's Avatar
I use the 3M spray adhesive, works awesome. Just be sure to spray the wood, not the carpet. Also get it on the way you want it, because once the carpet hits the glue, it sticks right away.
knewblewkorvette is online now   Reply With Quote
Old 06-03-2005, 08:35 AM   #4
EatRice
CF Senior Member
EatRice's Avatar
Send a message via MSN to EatRice
Actually Jay (unless something has changed with 3M products) you should spray both the wood and the material. Check the can for details. I have not used it in a long time. I spray glue from a paint gun
EatRice is offline   Reply With Quote
Old 06-03-2005, 05:15 PM   #5
knewblewkorvette
CF Senior Member
Damn you Randy , that's twice this week you had me second guessing myself.
Keep it up
According to the can, 3M General Purpose 45 Spray Adhesive, it states to spray the surface.
But...down below it says for a stronger bond to spray both surfaces.
It also states with one surface the tack range is 10 seconds while the two surface way is 15 seconds. I just never sprayed it on the carpet since I thought it might bleed through to the good side of the carpet The stuff sure sticks though
Old 06-03-2005, 07:57 PM   #6
scott_fx
CF Senior Member
scott_fx's Avatar
Quote:
Keep it up
thanks guys, i got the 90 stuff and it said both surfaces. it's came out great on the sub box and the amp rack is going under it's final construction (gotta go pick up some blue led case fans) I'll have pics by tonight or tomorrow.
Reload this Page how to adhere carpet to speaker box?
Tags
3m, 45, adhere, angeles, box, carpet, carpeting, general, glue, los, purpose, speaker
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
