Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-02-2005, 12:29 PM   #1
Billy182
CF Senior Member
Default Any high output alternators made for the C5?
I'm looking to buy a higher output alternator for my car, and am having a hard time. Does anyone know a good make that's available? I've heard of Irragi, but can't seem to locate his website. Any help would be more than appreciated!
Billy182 is offline   Reply With Quote
Old 06-02-2005, 03:38 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i believe that the best way to get a higher output alt. is to rebuild a stock one. I guess we'll wait for eatrice to chime in on this one to be sure
scott_fx is offline   Reply With Quote
Old 06-02-2005, 03:51 PM   #3
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
From my understanding the stock one is not rebuildable. I have guy that builds custom alternators. I have two of them and DIYNoob has one also. They are not cheap but they make over 240 amps and plug into the factory alternator harness. I have talked to people all over the country and till this day his alternator is the only one I have psoitive confirmation on that works properly in the C5. I have a spare that I will most likely sell or can get you in contact with him for a new one. PM me for details.
EatRice is offline   Reply With Quote
Old 06-02-2005, 04:02 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
i stand corrected. thanks eatrice
Old 06-02-2005, 10:21 PM   #5
Billy182
CF Senior Member
Quote:
Sounds great! lol, but now for the next dilemma: is it exactly the same casting? I've got an eight rib pully (from the supercharger) and not only that, I've got the early style rear bracket that bolts to the back of the alternator in two locations (the tension of the eight rib belt bends the newer style brackets). So, the output of this alternator sounds good, as long as it fits just like the original part
Old 06-02-2005, 10:58 PM   #6
EatRice
CF Senior Member
EatRice's Avatar
Billy....I will have to check. My alternator bolts directly into factory location and has a 8 rib belt on it....my car has a F1R on it. I am almost positive mine does not have the loaction for the mounting bracket. I will find out for you soon though. My car is not here to look at but I will be going to it's location tomorrow or Sat.
Old 06-03-2005, 12:16 AM   #7
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
knewblewkorvette's Avatar
I have purchased a Iraggi altenator off Don. It is a 220 amp for my S-15 Jimmy. The sob is huge compared to the stock one but he included a bracket with the altenator so it would still use the same spot and belt. I've yet to confirm it's actual output ( my multimeter only will hanle 10 amps ) but will do at my friends shop soon.
IMO, the stock C5 altenator is a great OEM altenator. I'm running nearly 2,000 watts rms and have zero problems.
I do plan on using EatRice's friend to upgrade my red Talon altenator.
Randy, please e-mail me that guy's phone number again.
knewblewkorvette is offline   Reply With Quote
Old 07-30-2005, 02:18 AM   #8
c52k1vert
916/795 rwhp C5R 412 YSI
c52k1vert's Avatar
I had Ohio Generator build one for me. It is able to put out 200amps at idle if needed. $950 USD... Ouch!
__________________
c52k1vert
'01 Mag Red II C5R - 412 CI
916/795 rwhp/rwtq on 93 octane & closed exhaust
20 PSI - Vortech YSI
Mods & Photo Gallery
c52k1vert is offline   Reply With Quote
Old 07-30-2005, 02:35 PM   #9
NVTHIS
CF Senior Member
NVTHIS's Avatar
As stated above, the current alternator which is a Valeo cannot be rebuilt. I had to go with a Delco CS 144 (I think that's what it was) and had it built to put out a little over 200 amps. I did have to buy a different bracket from Alternatorparts.com. I just went to my local Alternator rebuilder and had them build me one.
__________________
1999 Nassau Blue FRC complete Z06 conversion
N/A: 407.55 rwhp, 385.02 rwtq
Tuned by Charles Barber and V8muscle.net
Mods: Halltech ported TB, Halltech Tric, Kooks LT's, Kooks x-pipe w/ Hi-flow Cats, ECS "Big" Blower cam, Manley Double Roller TC, Comp cam high tech pushrods, Patriot Extremes, Pinned Crank, NGK plugs, MSD wires, 160 T-stat, B&B Bullets, Bilstein Sports, Textralia OZ700, Remote speed bleeder, Nassau blue depos, Tigershark Fascia, Mallett 396...
NVTHIS is offline   Reply With Quote
Reload this Page Any high output alternators made for the C5?
Tags
2000, 2005, alternator, alternators, amps, c5, c5corvette, corvette, factory, high, output, specs, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
