Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2005, 08:59 PM   #1
gogo4
CF Senior Member
gogo4's Avatar
Send a message via AIM to gogo4 Send a message via MSN to gogo4 Send a message via Yahoo to gogo4
Default 0 Gauge Installation!
Im using my 0 gauge wire but can't find an opening from the engine bay to the inside of the car anyone got some close up pics or a real detailed description on where i can pull this humango wire through ?
gogo4 is offline   Reply With Quote
Old 06-01-2005, 11:41 PM   #2
EatRice
CF Senior Member
Support Corvetteforum!
EatRice's Avatar
Send a message via MSN to EatRice
Passenger side kick panel. Remove the fuse panel cover and remove the sill plate. You have to look up under the dash you will see a piece of black rubber with foam on the back of it. Pull that down but do not remove it. Behind that you will see the fire wall. You will see a large rubber grommet to the right of the grommet you will see a slight triangular piece of the firewall. You can drill a hole there and insert a grommet. It is best if you remove the battery before hand. Then do a check to verify the drilling location on both the interior and exterior side of the fire wall. It is really a piece of cake and leaves plenty of room for 0ga. I have 0 going through there and several other wires in another grommet.
EatRice is offline   Reply With Quote
Old 06-03-2005, 12:17 AM   #3
knewblewkorvette
CF Senior Member
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12
knewblewkorvette's Avatar
totally
knewblewkorvette is offline   Reply With Quote
Old 06-03-2005, 12:57 AM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
i just rewired mine with 4 gauge in the location that eatrice had mentioned....one question...how in the heck do you guys hide 0 gauge wire???
scott_fx is offline   Reply With Quote
Old 06-03-2005, 02:04 PM   #5
knewblewkorvette
CF Senior Member
I get the clear coated 0-guage, the wire then is invisible
Old 06-03-2005, 02:10 PM   #6
EatRice
CF Senior Member
EatRice's Avatar
Quote:
You licky bastage.....I can never find that stuff. I am always told it is in stock but the packages are empty...lol.
Scott when it comes to 0ga it really is important to use a high quality wire. Generally the higher quality wire is alot more flexible then lower grades. The flexiablily allows the wire to be tucked away better.
Under my hood I ran the 0ga from the battery to the alternator under the wind shield wiper cowl. Only place I could really get the wire through the engine bay without possible problems.
Reload this Page 0 Gauge Installation!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Need urgent advice for installation tomorrow for 92 deck Lord Odin Audio/Electronics 11 01-22-2003 07:00 PM
Need Help With Finishing Installation....Please Help! USMUSCL C5 Tech 17 10-30-2002 07:15 PM
LPE supercharger in Car and Driver! Sparticus C5 Tech 49 03-11-2002 09:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
