Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-30-2005, 11:23 PM   #1
-Turk-
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Support Corvetteforum!
-Turk-'s Avatar
Default Template for Components in doors???
I need a template of a plate for installing components in my doors. BTW: MB Quart Reference 6.5 components. Where to mount the crossover???
-Turk- is offline   Reply With Quote
Old 05-31-2005, 01:35 AM   #2
markcz
CF Senior Member
markcz's Avatar
There is plenty of room inside the bottom of the door for the crossover if you don't mind using double sided tape.
I don't know about a template, but you can contact forum member VrumVrum to get mounting brackets that are already cut.
__________________
2007 LeMans Blue/2-Tone Gray Coupe w/MN6, 3LT, Z51, QX1, CC3, R8C Mods List
markcz is online now   Reply With Quote
Old 05-31-2005, 07:35 AM   #3
EatRice
CF Senior Member
EatRice's Avatar
Send a message via MSN to EatRice
You can use the factory speaker mount as a template and I would not mount the crossover in the door unless you mount it between the door panel and the inner skin. It is very easy to run wires into the door it would be best to mount the xover somewhere else.
EatRice is offline   Reply With Quote
Reload this Page Template for Components in doors???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2 x 5.25" in front doors (2001 vert) c5_convertible Audio/Electronics 10 11-04-2003 08:30 PM
Are these amps any good?............... LuvmyC5 Audio/Electronics 13 05-16-2003 12:23 PM
C5 audio system advice needed pls KorbenDallas Audio/Electronics 10 04-29-2003 05:18 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
