Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-30-2005, 09:20 PM   #1
cmeflyby
CF Senior Member
Support Corvetteforum!
cmeflyby's Avatar
Location: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Default please help! c5 wiring
i'm trying to install my XM tuner and i need to find constant power in the pass footwell but i don't have my voltmeter or a test light.
i found a small harness section with a connector tucked in the upper left hand corner. it has 3 wires: black, orange, yellow. usually this combo by itself is a good sign so i unplugged the connector and pulled one end out as far as i could. i started unwrapping the electrical tape from the factory and i found the yellow wire on the end that i pulled doesn't go anywhere, it's just about a 2" long piece that was covered under the tape. what is this and can i tap into it?
if this one isn't good, can someone please tell me exactly where i can tap into? a pic would be awesome. i've read other threads that say in the pass footwell but can't really tell where exactly to tap.
thanks!
cmeflyby is offline   Reply With Quote
Old 05-31-2005, 01:23 AM   #2
markcz
CF Senior Member
markcz's Avatar
The three wires you found are exactly what you're looking for
Most people know about the 'accessory wires', but can't find them. You apparently found them without knowing they were there
The wires are explained in your owners manual, but you can click here to check out the schematic for them. The yellow wire is the switched power wire, orange is always hot, and black is the ground.
markcz is online now   Reply With Quote
Old 05-31-2005, 05:39 AM   #3
cmeflyby
CF Senior Member
cmeflyby's Avatar
thanks Mark. since i couldn't get a quick answer i went to my shop manual and started looking at the schematics. i never was able to find the one in your shortcut.
so, i started looking at the BCM and found wire A4 on C3 is a constant hot fused wire and tapped into it. hopefully it's OK to do this , my XM tuner works fine. for ground, i tapped into the hatch latch motor harness in the back.
thanks!
Reload this Page please help! c5 wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Please help!!! I have a question about a wire we cant identify EricG33 C5 Tech 17 12-20-2003 06:52 PM
C5 Techs...please help me!!!! Drop_Top_Dave C5 Tech 10 10-01-2002 11:39 AM
Please help with spark knock. Especially anyone that has or has had a 85 C4 Duntov85 C4 Tech/Performance 22 09-14-2002 12:58 PM
Please help with nitrous wiring! OliverM5 C5 Tech 9 06-26-2002 10:41 PM
Please help me locate connector for changer, see Pics. RPOZ4Z C5 Tech 14 12-01-2001 02:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
