amp location
amp location
Whats a good place to mount the amp in a c4 coupe? My guy is looking to drop one in the rear storage compartment, but I have a concern about the heat....
USMC (retired)
On my C4 I mounted mine flush on the back of the coupes trunk (vertical, not horizontal)....sorry I don't have pics to show this. I am looking at doing the same thing to my C5, hopefully the JL 500/5 will fit back there.
mounted flat on the floor in the back with a false floor over them and factory carpet
mounted on the back wall and behind the seats
all my pictures can be seen here: http://www.sounddomain.com/memberpage/479196/1
I put mine under the passanger seat (not a powered seat). They are fine there, they dont' generate much heat so no problems whatsoever. Very easy grounding too since the seat bolts are grounded.
I just finished installing a budget system in my 91. I mounted my Elemental Design Nine.4 on the vertical surface in the rear of the hatch. I glued a piece of 3/4 inch plywood with liquid nails and screwed the amp to it.
Worked nice.
-Mike
Worked nice.
-Mike
