Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-25-2005, 06:48 PM   #1
Rob 99
CF Senior Member
Support Corvetteforum!
Rob 99's Avatar
Default 12v accessory tap
where did you guys tap into for a 12v w/ key in access postion,empty fuse #22 is only hot when key is in the run postion. thanks in advance.
(BTW this is for a aftermarket HU install)
Rob 99 is offline   Reply With Quote
Old 04-25-2005, 08:26 PM   #2
vectorz
CF Senior Member
vectorz's Avatar
I tapped into the brown wire of the ignition.
vectorz is offline   Reply With Quote
Old 04-26-2005, 02:40 AM   #3
Rob 99
CF Senior Member
Rob 99's Avatar
Quote:
Was it easy to get to? did you remove the ignition itself? thanks.
Reload this Page 12v accessory tap
Tags
12v, accessory, c6, corvette, removing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
Another CB Radio & C5 Question TexasMadMan C5 General 13 06-22-2005 01:08 PM
Help, c5 bose, sub and amp instal questions. Z06FROMHELL Audio/Electronics 12 03-20-2005 06:59 PM
All 4 lites on at once & CLEAN YOUR RADIATOR! geezer C5 Tech 19 10-17-2003 11:35 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
