Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2005, 03:39 PM   #1
black_89_vette
CF Senior Member
black_89_vette's Avatar
Send a message via MSN to black_89_vette
Default Mono amp with 2 subs
Sony Xplod XM-D500X http://sm.crutchfield.com/S-Xnbv0Vuq...rch=xm%2Dd500x
Rockford Fosgate P210S4 http://www.rockfordfosgate.com/produ...h%20Subwoofers
I initially was going to install the amp with the one 10 " sub. But, guess what? They shipped me 2 10 " subs by error. So it now seems I'll be using both.
Since the amp is rated at 250 W RMS @ 4 ohms, and the subs are 200 W RMS @ 4 ohms, will the amp's power be split since I'm using 2 subs? Will it be enough and will it hook up properly to 2 subs?
black_89_vette is offline   Reply With Quote
Old 04-22-2005, 05:38 PM   #2
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
you'll be fine, the amp is two ohm stable so you can push both of those subs and they'll be getting 500w rms total. just turn down your gain a bit.
scott_fx is offline   Reply With Quote
Old 04-22-2005, 05:40 PM   #3
scott_fx
CF Senior Member
scott_fx's Avatar
wire it in parallel:
http://www.eatel.net/~amptech/elecdisc/spkrmlti.htm
Reload this Page Mono amp with 2 subs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need a 2 ohm stable 4 channel amp...suggestions??? LPDesRoche Audio/Electronics 11 10-13-2003 12:04 PM
2 8" subs in a c5? calivette Audio/Electronics 10 06-07-2003 06:42 PM
one 4-channel vs. one 2 channel & 1 mono? '71vert Audio/Electronics 11 06-04-2003 02:11 AM
amp question LD85 Audio/Electronics 19 06-25-2002 02:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
