yes but, the one in the vette is running at 2.66 ohms.
In my Talon, I ran them at 1.5 ohm or 3 ohm, depending when I had one or two subs.
I did run one 1200.1 into 4 subs at 1 ohm in my truck , the subs gave up before the amp did. That system got stolen
Sorry to here yours clip. Maybe you need this
SPECIFICATIONS
CEA Rated:
Click here to learn about the new
CEA2006 Amplifier Standard.
Power Output: 2600 Watts RMS x 2 channels at 4 ohms
and ≤ 1%THD+N
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
7400 Watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio: 65 dBA (reference 1 Watt into 4 ohms)
Dynamic Power: 6854 Watts at 4 ohms
Effective Damping Factor: 6.39 at 4 ohms
Frequency Response: 10Hz to 270Hz (-3dB)
Maximum Input Signal: 8.5V
Maximum Sensitivity: 250mV
Output Regulation: .2 db at 4 ohms
Dimensions (H x W x D): 6-1/2" x 29-3/8" x 23"
MSRP U.S. $: $6000.00
RESOURCES
Downloadable Owner's Manual (PDF)
Register Your JBL Car Product
2Ω & Dual 2Ω Subwoofer Wiring Diagrams
Click here for the full A6000GTi story.
for an Automedia Interview with Gerald Stanley, the man behind the A6000GTi.
