Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-24-2005, 02:53 AM   #1
DanielW
CF Senior Member
St. Jude Donor '04-'05-'06-'07-'08
DanielW's Avatar
Send a message via ICQ to DanielW Send a message via AIM to DanielW
Default [Total Newbie] Replacing HU. What will I need?
I really want an MP3 deck so I've decided to pick up an Alpine CDA-9853 HU. Not looking to add a lot of stuff as I am not really into the whole sound thing. What else would I need to make this HU run after I take out the stock HU. Where can I get a plate so the HU will fit the big ass hole that the stock radio will leave. Also I heard that the bose woofers won't work if I take out the stock radio. Should I replace front speakers as well? any info and tips would be appreciated. I am a total newbie to this and even the most simple tips and advice are welcome.
DanielW is offline   Reply With Quote
Old 03-24-2005, 04:13 AM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
I need to learn more about how C5 bose systems are put together... then I could answer this for ya.
I am sure that there will be someone here who can help!
bogus is offline   Reply With Quote
Old 03-24-2005, 12:28 PM   #3
RedRider98
CF Senior Member
RedRider98's Avatar
The headunit will run the front door twiddlers (3.5") and the rears. The subs in the doors WILL NOT work unless you buy an adapter. It would be much better and more cost effective to save the money on the adapter and replace the door speakers entirely. You should also replace the rears with a good quality coaxial. I just got finished with this on my '98. If you need custom front door speaker mounts, forum member 'vroomvroom' makes them custom for a great price!
Bryan
RedRider98 is offline   Reply With Quote
Old 03-24-2005, 02:19 PM   #4
Ebein
CF Senior Member
Ebein's Avatar
I also did mine last weekend with an Alpine 9833 you can see
the pictures here
Bills Stereo Install
Holler if you have any questions and Good Luck
__________________
Bill Linton
Ebein is offline   Reply With Quote
Old 03-25-2005, 01:14 AM   #5
DanielW
CF Senior Member
DanielW's Avatar
Lets's say I take out the woofers and put in bigger aftermarket speakers in their place. Would I lose a lot of bass? Would I need to run new wiring from the HU to the doors?
Old 03-25-2005, 02:12 AM   #6
Ebein
CF Senior Member
Ebein's Avatar
I would and did run new wire
Old 03-25-2005, 10:43 AM   #7
RedRider98
CF Senior Member
RedRider98's Avatar
It would be much better to run new wire, but if you don't want to, there is a solution. In the door wiring that plugs into the Bose sub unit, you can cut the positive and negative speaker wire and wire it to the new speakers. I believe the colors are gray and tan on the driver side and green and light green on the passenger side. Note, there are two tan wires and two light green wires. Try them both, one will only give you mids and highs and the other will give you full range. I tried it and it worked, but I ended up running new wire.
Reload this Page [Total Newbie] Replacing HU. What will I need?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
