Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-27-2005, 12:43 AM   #1
GKK
CF Senior Member
GKK's Avatar
Default Upgrading base Delco sound system.
I'm tired of listening to the stock cassette stereo (non Bose) in my "91" Vette and after many many hours searching in this forum and online, I've finally decided what I want to do.
For now I've decided to just improve the sound by replacing the front speakers and adding a 4 channel amp and either one 8" sub behind the stock rear panel or two 6x9 subs (if I can find them).
I plan on connecting the amp using the high level inputs to the Delco receiver then connect the front channels of the amp to a set of component speakers and bridge the rear channels to the subwoofer(s).
Here is a list of the system components I'm planning to use. Although sound Quality is very important to me, I'm trying to do this as cost effective as possible so, some compromises had to be made. (budget around $400)
1) Profile AP1040 80wx4 @ 4 ohms, 255wx2 @ 4 ohms bridged 4 channel amp. 12db variable Treble and Bass boost,
12db/octave HP/Full/LP Crossover,
Variable LP Crossover Frequency-50 - 250 Hz
Variable HP Crossover Frequency-80 Hz -1.2 kHz ($109.95) The Zeb.com
2) Infinity Kappa 50.5cs 5 1/4" component speakers. ($223.99) Crutchfield.com
3) One or two 8" subs either Rockford Fosgate (two for $79) or two 6x9 subs. Crutchfield.com
I'm going to add an Alpine CD player around the end of the year but this should work well until then.
I would appreciate your expert opinions or suggestions on any changes that I should make. Thanks
GKK is offline   Reply With Quote
Old 02-27-2005, 01:37 AM   #2
JCAIRE2
CF Senior Member
JCAIRE2's Avatar
Sounds like you've got the right ideas, I wouldn't buy from crutchfield though. They are good for looking at pictures and specs, but the items can be had much cheaper elsewhere.
JCAIRE2 is offline   Reply With Quote
Old 02-27-2005, 02:01 AM   #3
markcz
CF Senior Member
markcz's Avatar
Quote:
Click here to save yourself $92 on the speakers.
markcz is offline   Reply With Quote
Old 02-27-2005, 02:57 AM   #4
GKK
CF Senior Member
GKK's Avatar
Thanks for that web site!
I'm glad I checked here first before I ordered anything!
Old 02-27-2005, 02:30 PM   #5
pentavolvo
CF Senior Member
Cruise-In IX Veteran
pentavolvo's Avatar
Just lettin u know I persoanlly own a few profile amps and while they are not the nicest amps use will deff be happy with them. For the price you really can't go wrong unless you are some crazy audiophile or somethin you will never tell a sound quality difference
pentavolvo is offline   Reply With Quote
Reload this Page Upgrading base Delco sound system.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
