Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2005, 12:36 PM   #1
Golden80
CF Senior Member
Golden80's Avatar
Default Is there a way to tell difference between red/black RCA's?
I have RCA wires going from my head unit to an amp powering my component speakers. The RCA wires are not labeled in the typical black/red colors at the end of the wires on the connectors. Is there an easy way to determine which one goes where without pulling the entire cable out of the car to see?
Golden80 is offline   Reply With Quote
Old 02-18-2005, 01:23 PM   #2
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
yes!
do you own an ohm meter or continunity tester?
RPOZ4Z is offline   Reply With Quote
Old 02-18-2005, 01:51 PM   #3
Gray Ghost
CF Senior Member
Gray Ghost's Avatar
Quote:
Originally Posted by RPOZ4Z
yes!
If not, you can get one fairly inexpensively from Radio Shack.
Gray Ghost is offline   Reply With Quote
Old 02-18-2005, 02:03 PM   #4
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
why dont you just hook it up to the amp and use your fade and balance controls to figure out what goes where?
scott_fx is offline   Reply With Quote
Old 02-18-2005, 10:01 PM   #5
Golden80
CF Senior Member
Golden80's Avatar
yes!
I have one somewhere.
Old 02-18-2005, 10:13 PM   #6
Kale
CF Senior Member
Kale's Avatar
I agree, plug it in, if its wrong, switch em around. No need for any kind of complicated testing.
Kale is offline   Reply With Quote
Old 02-19-2005, 08:57 AM   #7
RPOZ4Z
CF Senior Member
RPOZ4Z's Avatar
that sounds like an easier way.
Old 02-22-2005, 08:06 AM   #8
corvette-pilot
CF Senior Member
corvette-pilot's Avatar
One of the wires should have a mark on it. A stripe or a raised ridge?? Just check both ends for the wire with this marking and you know they are one in the same.
corvette-pilot is offline   Reply With Quote
Old 02-22-2005, 11:39 PM   #9
gmosley
CF Senior Member
gmosley's Avatar
Default test
fade your radio to the left plug in one rca cable to the left channel on you head unit plug one into the left channel of your amp when your left speaker works you got it right
reverse the patch cable if it is playing the right side
that should do it
for future reference if you continue to use these patch cables mark one side so you dont have to do this again in the future
sometimes organization separates a good system from a great system
gmosley is offline   Reply With Quote
Reload this Page Is there a way to tell difference between red/black RCA's?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Kens Newsletter - June 30, 2005 Ken Fichtner Ken's Newsletters 15 07-22-2005 11:41 PM
Thanks Forum. My take on LMB Vert (Power) etc. Beakmeister C6 Corvette General Discussion 11 04-01-2005 03:00 PM
Kens Weekly Newsletter - 2/23/05 - 2006 News! Ken Fichtner Ken's Newsletters 11 03-01-2005 04:43 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
