Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-17-2005, 12:46 AM   #1
JBH
CF Senior Member
JBH's Avatar
Default JL Audio XR653-CS?
After reading this section for a month or so I have decided to gut my C5 and start over. I am in the process of gathering components. I am getting a subthump box, I have a MTX 7510-44 DVC sub and a MTX Thunder 895 amp. I plan on adding one of the new Alpine headunits and the JL 3 piece for my front stage with no rears. I was reading the manual for the 653's off JL's site and they said don't mount the 4" and the 6.5" in the same space and don't mount the tweet more than 4" from the 4" speaker. I know every setup I have seen in a C5 has ignored both or these mounting tips. Is there a problem with putting the 6.5" and 4" in the door and the tweet inside the door handle? Does it degrade the sound?
JBH is offline   Reply With Quote
Old 02-17-2005, 01:46 AM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
I don't know much about MTX amps... what I do is that I don't like them very much.
The idea about not wanting to run the 6" and 4" together is because the 6" could move enough air to disturb the 4", beyond that, I have no idea. I would mount all three into the door space and leave it at that. There is more then enough room to do this on a nice big baffle.
bogus is offline   Reply With Quote
Old 02-17-2005, 03:02 AM   #3
muddpile
CF Senior Member
Bogus is right. It is because the 6.5 is a midbass and the 4" is a midrange. The 6.5" could create pressure in the door to cause the 4" to distort. Even running some of those cheap parts store foam baffles behind your 4's should be all you need to remedy the problem. I run the 3 way XR's myself in my C4. They are an excellent choice!
muddpile is offline   Reply With Quote
Old 02-17-2005, 11:57 AM   #4
leolufse
CF Senior Member
leolufse's Avatar
Send a message via AIM to leolufse
The JLXR653's are a great choice. I've installed them in a C5 running from a JL300/2. The midbass is very strong and, unlike the JL 2-ways, the midrange is very full. I mounted the tweets in the doorpull, but up in the door panel would have raised the stage just a bit, but it still sounded very good. Don't put the tweet inside the door, its too low an will be blocked by the door panel. The C5 door is cavernous inside, there is enough airspace to even worry about the 6.5 affecting the 4". A baffle is a bad idea. These components are designed for IB applications.
leolufse is offline   Reply With Quote
Reload this Page JL Audio XR653-CS?
Tags
xr653cs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Should I change rear speakers or have none? advice? flyhawk04 Audio/Electronics 26 04-30-2005 10:24 PM
C5 stereo install question - having troubles here - PLEASE HELP! 2k1 Vette Audio/Electronics 12 03-03-2005 10:29 PM
I think I've got my weekend project all lined up. 2k1 Vette C5 General 16 02-26-2005 06:34 PM
need help??? you know c5 stereo info?? flyhawk04 Audio/Electronics 11 12-20-2004 02:21 AM
Car stereo face plate ?? flyhawk04 C5 Parts for Sale/Wanted 18 12-17-2004 12:40 AM
Focals - MB Quart - Not THis Time! webdzynes Audio/Electronics 17 10-29-2002 09:00 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
