Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-16-2005, 12:16 AM   #1
vertte
CF Member
Default C5 door rattles
How the hell do you get rid of the door rattles on a C5 vert? I took the door panel off and the stock sound blocker underneath. Put dynamat on the inside of the door behind the window and reinstalled the sound blocker. Dynmatted around the door handles, openers, pulls, and anything else that looked like it could rattle. Dynamatted around the speaker grill on the inside of the panel, the window and door actuator buttons, too. And I still have rattles. One source appears to be the HVAC vent on the driver's side door (don't know how I'd get rid of that one). It's driving me batty!
Is the only option to get rid of the Bose speakers, move the sub to the trunk, and put midranges up front?
Anybody got a post or troubleshooting method how to do this? I tried searching but didn't have much luck.
Thanks, and I can't wait for summer to put the top down!
vertte is offline   Reply With Quote
Old 02-16-2005, 01:34 AM   #2
Grzldvt
CF Senior Member
Grzldvt's Avatar
I had severe rattles from the speaker covers and the foam in the doors.
I pulled the door panels, and tightened the tabs and super glued the Blose Emblem, then I used some very short, small sheet metal screws and screwed down the tabs on the speaker covers.
Then I took some silicone bluke, and gobbed up the tabs and the screws, so they would not come loose. I reglued the foam in the upper door panels with 3M Spray on Contact Cement. When I put the door panels back on I used some very thin weatherstripping, with adhesive on one side, and put it in between each pin hole all the way around the door. I took the weather stripping right up to holes, so when the panels snapped back on there would be tension on the pins and hold the panel much tighter.
I did this about 3 years ago, and it is still very solid with no rattles.
Grzldvt is offline   Reply With Quote
Old 02-16-2005, 08:26 AM   #3
noelc5
CF Senior Member
Send a message via AIM to noelc5
I've been having this same problem. I may try gluing things up and using the weatherstripping. I kinda like that idea.
I broke a couple of the plastic tabs but I'm hoping to replace those in the next few weeks.
noelc5 is offline   Reply With Quote
Reload this Page C5 door rattles
Tags
2003, back, c5, corvette, dealer, door, foam, grill, rattle, rattles, source, speaker, spray
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Rattles? BlackOps C5 General 14 08-09-2004 01:43 AM
TON's of info from the C5/C6 Birthday Bash! Jim Terry C6 Corvette General Discussion 29 05-07-2004 05:49 AM
C5 door speaker install... pics? Conquer Audio/Electronics 18 11-22-2002 11:19 AM
How to get rid of C5 door speaker panel rattles? jmX Audio/Electronics 15 04-19-2002 11:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
