Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Audio/Electronics
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-30-2005, 03:06 PM   #1
Corvettes White
CF Senior Member
Corvettes White's Avatar
Default Mounting radar detector inside HUD.
Well I got a new engine in our ‘99 so after 25 years of driving a Corvette without a detector, it is time to buy one. Planning on a Valentine One with the remote head unit. So, the question.
I want to mount the LED’s down inside the heads-up display for obvious reasons. Has anyone done this; ideas, thoughts?
Thanks in advance, George
__________________
1959 - No car, just my wife, Kathy.
1969 - 383 aluminum bow-tie block w/ a 70 LT1 induction, 4-speed convertible.
1979 - Sold to a man from Amador Co.
1989 - Building a 1989 LT5 powered vert. Have most of the parts. Just need time.
1999 - 7.0L 6-speed convertible, daily driver.
_666 - '06 C6 Z-06; Just dreaming.
Corvettes White is offline   Reply With Quote
Old 01-30-2005, 08:33 PM   #2
Still_Single
CF Senior Member
Still_Single's Avatar
Hi George ... I've been busy with work the last year - so I haven't been posting on the forum as much - but I thought I'd toss you a few teaser pics. I've been working on an improved Escort/V1 HUD off an on for the last 6 months. If I'd just get serious about it I could probably finish in just a couple of nights - but there's always something ...
The first pics are when I just had the 2 Escort SR1s installed. (front/back).
Still_Single is offline   Reply With Quote
Old 01-30-2005, 08:35 PM   #3
Still_Single
CF Senior Member
Old 01-30-2005, 08:36 PM   #4
Still_Single
CF Senior Member
Old 01-30-2005, 08:37 PM   #5
Still_Single
CF Senior Member
Here is part of the new design - call it phase 3. (I don't have a pic of phase 2 - just the 2 SR1s and the V1) Phase 3 includes the 2 SR1s (I still like them, but I also like the V1 arrows), the V1 remote display, a Dakota Digital clock, and a Dakota Digital 4x Temp display for my stereo. Obviously there is a lot of extra ribbon cable in these pics - it'll look much better when I'm done - promise! I'll try to finish up in February so I can post some completed pictures. Hopefully this will give you some ideas...
Good Luck!
__________________
Old 01-30-2005, 09:06 PM   #6
Mike04
CF Senior Member
Mike04's Avatar
I'd love to add to the HUD... this looks like way to much work for the average guy though!
Mike04 is offline   Reply With Quote
Old 01-30-2005, 10:56 PM   #7
Corvettes White
CF Senior Member
Cool
I assume that one need just mount the readout light sources and the rest is taken care off.
From the drawings the color is filtered. Nevertheless, it looks like red shows clearly. Do I need to worry about color?
From the drawings, the reflecting mirror is curved. When you add the LEDs, etc. do you need to compensate?
Did you tie-in the light sources to the dimmer?
Is there a lot of real estate to work with?
Looks like I should buy a second HUD to work up.
Thanks, George
Old 01-31-2005, 01:17 AM   #8
Still_Single
CF Senior Member
You've made some good observations ...
The color is filitered, but it works a little different than you'd think - the image reflects off the filter rather than going through it. Red LEDs do not work well during day light. They look great at night, but can completely fade out in the sun. You can't tell from the photos - but one of the reasons for the hand made LED array around the base FL HUD display is so that I could switch from the V1 red LEDs to bright blue ones. There's no need to compensate for the curved mirror - it actually helps line things up on the curved windshield. There is not a lot of room in there - it's easy to block part of the HUD display. That's why the circuitry for the clock and temp guage had to be outside the case. For the dimmer I brought the SR1 and V1 light sensors out into the open part of the case - so that they work normally. If you look closely in the pictures you can see the bare photo sensors.
FWIW - The U shaped LEDs around the base FL display (the last 2 pics) were a part of phase 2 - it worked, but not as well as I'd hoped. Part of the blue LEDs were being blocked - the HUD wasn't designed to have a light source outside of the main FL display. The new plan is to integrate them into the bottom piece of black plastic in the case - the piece that the SR1 LEDs are behind in the first set of pictures. That location works well with the mirror and places the LED image on top of the speedometer - a good location for a warning indicator.
Old 02-12-2005, 12:25 AM   #9
Corvettes White
CF Senior Member
Still Single. Thanks for the help.
George
Old 02-14-2005, 03:48 AM   #10
bill mcdonald
CF Senior Member
Wow! that is some serious work. I am keeping an eye on what you do as well!
bill mcdonald is offline   Reply With Quote
Old 02-14-2005, 01:38 PM   #11
scott_fx
CF Senior Member
scott_fx's Avatar
Send a message via AIM to scott_fx
Quote:
This is so cool! keep us updated and i hope you're going to post a 'how to'
scott_fx is offline   Reply With Quote
Reload this Page Mounting radar detector inside HUD.
Tags
bill, chesapeke, corvette, detector, detectors, display, escort, heads, hud, install, mcdonald, mounted, radar, va, valentine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
